TwinTurbo.NET: Nissan 300ZX forum - Probably still air in it. Did you bleed the fender line
Subject Probably still air in it. Did you bleed the fender line
Posted by Audioquest on May 06, 2008 at 1:58 PM
  This message has been viewed 129 times.
In Reply To Faulty clutch slave cyl or master cyl or bleeding error?? posted by fastertt on May 06, 2008 at 01:01 PM
Message first and then do the slave? If it's not that, could be the MC, but I'd try bleeding it again. Use an assistant that can work the pedal while you open and close the nipple...making sure you top it up every 2 strokes.
